Hi people
I have a BEC with a Honda CBR1000 with an adapter flange off the output shaft which has a 4 hole 70mm PCD. Does anyone know what vehicle has this type
of prop with a UJ/CV to this spec?
Regards
James
If it's the smaller diameter one than later Ford they were used on Reliants and Marinas and some earlier Mk1 Escorts. Prop suppliers carry them as they are used in industrial applications as well as automotive.
OK, I'll try that - thank you.
James
