R1 Starter Relay connections...
Winston Todge - 21/10/06 at 03:57 PM
I'm having a few problems wiring up the engine due to a Cyclelock (or lack of it) problem. I have overcome this by grounding the starter relay output (blue/white) wire and then the motor turns over fine.
The only problem is that it doesn't spark. If i have bypassed the starter relay in the way mentioned above, will it stop the ECU from sending sparking info to the LT side of the coils?
Any help'd be much appreciated,
Chris.
smart51 - 21/10/06 at 04:34 PM
U2U sent
RichieC - 21/10/06 at 10:54 PM
As per other thread mate, have a look at my build diary to see how I got round this problem with a non cyclelok loom
Rgds
Richie
[Edited on 21/10/06 by RichieC]
