just been reading through a previous
threadhttp://www.locostbuilders.co.uk/viewthread.php?tid=67564
which hole do i block?
[Edited on 18/6/07 by adrian]
hole no 1
Yep, hole number 1.
just out of interest why do you have to block one of the holes off
adam
[Edited on 18/6/07 by oadamo]
thanks guys!
oadamo- i think its to improve the response of the slider?
can anyone provide more info?
the jet that you block feeds air into the needle jet. What I think it does is lean the fuel off at high revs / full throttle whilst keeping the fuel rate up at mid revs. This is to match the restriction in airflow caused by the exhaust / airbox at high flow rates. When you fit freer flowing parts to your engine, you want a more linear fuel flow so you block up the hole.
would this still be a good idea in a bike engined mini?
as the air flow isnt as good as a 7 type vehicle
z cars recommend 128 main jets perhaps because lack of air flow?
should i think about some ram air?
