with my SVA date now confirmed, could anyone tell me how to adjust the fuel air mixture on a 1999 R1 as im sure itll be running to rich and will need
some kind of adjustment.
Im sure i could work it buy looking but thought id ask peoples advice for ther best way to do it first.
I know lots of people see them as the spawn of the devil but I quite like colortunes for setting the idle mixture needle.
For sorting out running mixtures there's nothing like a wideband lambda sensor though
For sorting out running mixtures there's nothing like a wideband lambda sensor though![]()
Take it to your local friendly garage and get them to set it up in accordance with the MOT cat test using their gas analyser.
Thats what i did and it cost me all of £20
I went to a local MOT place and they let me use their gas analyser for free.
Adjust all the cylinders by the same amount, a little at a time.
I took mine to my local friendly garage. They hooked it up to the gas analyser and all the gaffer called all the apprentices and young 'uns over
to watch. He then leant over the car and started turning the idle screws.
Just then there is a sort of melting nylon smell, all of a sudden the gaffer leaps backwards, starts hopping round the garage swearing
He'd only been leaning his shins against the exposed exhaust! Melted right through his overalls.
How the apprentices laughed at the old master!
After that, he left me alone to set it up myself, with the rest of the lads helping with readings etc.
Funny but he didn't even charge me!
Mike
Chris, Somewhere in my garage i have a colortune set if you want to play
Roger
