Minimum Wiring for 893 Blade
PeterW - 28/3/08 at 10:17 PM
Evening all
I'm going to be wiring the blade next week, and the plan is to use the minimum bike loom needed to start and run the engine.
I've got an 893 carbed engine, correct ECU, regulator, coil packs and starter solenoid. What I want to do is wire the engine electrics as a single loom section, so what is the minimum I need...?
Anyone got a cut down wiring diagrm showing whats needed..? I'll be taking out all the switches except neutral.
Any tips gratefully received !
Pete
rgrs - 29/3/08 at 08:01 AM
The minimum wiring is using just the ecu and coils
ecu colours : Green, green+white & light green = Earth
yellow/yellow+white to pulse generator
Black+white= +12v
Yellow+Blue= Coil pack cylinders 1 & 4
Blue+yellow= Coil Pack cylinders 2 & 3
You can then use the starter relay as follows
Green+red = Earth
Yellow+red = +12 applied to start from (black+blue from the sierra ignition switch i think)
Thats the minimum but you could use the entire loom and just extend it where necessary.
hth Roger
richmars - 29/3/08 at 08:17 AM
It's a few years since I did this, but I seem to remember having to do something with the clutch(?) switch.
shortie - 29/3/08 at 10:53 AM
This might help.
http://www.dewweb.co.uk/indyblade/images/Indyblade_wiring_v17.pdf
Rich.
Kev99 - 29/3/08 at 12:32 PM
I've got it on a adobe reader file pinched off a web site that's not there anymore if u want it u2u me your e/mail address and I will send it to u
Kev.............
Kev99 - 31/3/08 at 03:03 PM
Hope It Helps
