SVA PC map for Hayabusa
iiyama - 9/5/08 at 06:58 PM
Anyone got an SVA friendly map for the busa?
Ian
Jason Fletcher - 9/5/08 at 10:17 PM
Hi Ian
sorry can't help you on the map but I am intrested what ECU you are using that allows you to map it?
Jason
eccsmk - 9/5/08 at 10:22 PM
i think he is using a power commander
LINK
Jason Fletcher - 9/5/08 at 10:30 PM
Ah right. I have a power commander too and have not got the slightest clue how it works... If you find a SVA map I could do with a copy because I will need to SVA mine later this year.
jason
eccsmk - 9/5/08 at 10:44 PM
i dont think there will be a set map for sva best off taking it to someone who knows how to map them because each exhaust and airfilter combo will be different on each car
HTH
iiyama - 10/5/08 at 08:05 AM
Sorry, should have been a little clearer! Power Commander USB III is indeed what its for.
Realise that exhausts will probably differ but didnt think that it would be that important due my understanding that the Hayabusa is a ba$tard to get through emmisions at SVA. From what Ive heard the car is pretty much undrivable on the map required to get it to pass?? So to that end would have thought the map was pretty much standard, with maybe a tweek here or there to get the result.
Looking for a place to start really!
richard thomas - 10/5/08 at 06:51 PM
Mine went through without a power commander, know of at least one other too! Just used a good Cat and fuel pressure wound down from 43 psi to 27 psi.
I believe that this is the advice Westfield give to megabusa builders.....
iiyama - 11/5/08 at 01:39 PM
Interesting!
