Can anyone tell me if the blade engine mounting thread pitch is 1.25mm please?
Thank you in advance
It definalty fine thread, your avatar always makes me smile!!
HTH Mike
The avator just shows why men should have control of the remote !!
Regarding the thread I have found that it is fine thread but just need to ensure how fine before I make my purchase.
thanks in advance
You could drill out the hole and just use a bolt with locknut.
There is M12 x 1.25 and M10 x ? can't remember. But 100% on the M12.
Hope that helps (A little)
M10 x 1.25 too.
it is on a 919 at least
tom
[Edited on 3/6/08 by indykid]
M10 x 1.25 on a 893 aswell as I had the same problem. I couldn't find any bolts with the thread long enough though so I had to buy a tap/die thingy.
