Blade Very hard to start when hot
Been ok for the last couple of years
Needs push starting most of the time
Any ideas where to start looking
[Edited on 8-6-08 by Kev99]
Bump starting????
is it injection or carbs??
Fuel evaporation maybe??
Sorry should of said its an 893 carbed
running with everything as standard including air box
mhh everything standard is not quet common on here i guess..
many times you need a rejet to adapt it to the air intake on the car.
running lean is bad for an engine..
check your plugs.../ clean the carbs...
Tks
It's running a standard engine setup including standard airbox, so if anything it may be getting even less air than it did in the bike, so
running lean would prob not be an issue.
When it's hot have you tried to start it at full throttle?
Tks
Hi
Had a simular problem on an old GSXR400 suzuki bike
New coils fixed it
No Idear why.
Needed to wait 30mins cool down be for start.
Strange thing was if I stalled it using the choke it would restart.
Very weird.
