hiya i have a 4xv r1 engine and clocks in my car and and for some reson where the temp is ment to be shown it just says lo all the time any ideas im also running standared r1 rad
Electrical problem or thermostat stuck open.
it worked when if first come back but stoped the next day
The r1 dash always displays 'lo' untill the engine reaches 40 degress then it will show the actual value.
That's what my '05 R1 dash does anyway.
i know but even after a short drive still dont move
Just leave it idling for a good 10 mins or so. It will get above 40 no probs. If it still says LO when the fan kicks in then you have a minor wiring
problem
It says lo until the temp sensor gets to 40°C. Leave it to idle for 10 minutes as stated and it should get really hot.
Is the sensor in the R1 rad or have you moved it? Put your hand on it carefully. If it it hot then you should see something on the dash.
Its only 2 wires. If the wires bell out to the clocks then chances are it is the sensor. You could try unplugging the sensor and putting resistors
across it. Get the right values and the clocks should show a temperature.
hi all sorted it a wire had come off the rad
