exup bypass
iceman26 - 27/9/08 at 10:17 AM
can someone give me a list of parts need for exup
bypass box of tricks
thanks
Davey D - 27/9/08 at 11:35 AM
which engine are you using? if it is for the R1, then you can find the circuit diagram on here is you do a search
Paul TigerB6 - 27/9/08 at 12:39 PM
May as well copy it in here as i just did it in the other thread!!
[Edited on 27/9/08 by Paul TigerB6]
a4gom - 27/9/08 at 01:22 PM
If its unplugged does it make a difference apart from the error code?
Does this work for all models?
We are converting 2 cars to 2005 5VY R1's, i'll be using the bike clocks so will need to make something up but my mate is using different clocks so if it don't make a diff he won't need one.
iceman26 - 27/9/08 at 01:43 PM
i have got info from a post on hear and they put up picture of there receiptand i have all but 1 part not sure what it is. receipt in picture and maplins have no part number for it .
the number on the receipt is qq41 4503 i need to know what it is so i can order 1
Davey D - 27/9/08 at 06:22 PM
Ok people ive found what you need here:
exup replacer
exup replacer
i have used this circuit on my 2006 5vy R1, and it seems to work fine. Only thing i will mention is on my 2006 5vy one of the wires is a different colour to the wires on this diagram... all the others are the same, so i hooked up all the correct colour wires, then connected the last one up to the remaining connection on the circuit
[Edited on 27/9/08 by Davey D]
