Rs Turbo
ZetecNology - 6/8/09 at 04:51 PM
Hello all after a little turbo wisdom
Ive just struck a deal with somebody whos about to break a fiesta rs turbo, to get all the needed parts to build my zetec turbo soon.
Hes asked for a detailed list of what exactally im gonna need from the fiesta?? Ive got all the main parts in mind (both manifolds, turbo etc). But could someone please write me a detailed list of everything id need from it incase i forget something? Any help greatley appreciated, Cheers
eznfrank - 6/8/09 at 05:28 PM
ECU, loom and all the sensors. Are you using the car as a donor or just the engine?
jpindy3 - 6/8/09 at 06:09 PM
you might need the bosch injection as well,if it is a cvh they use the k-jet injection witch is quite dated,also you might need the crank pulley for the sensor.
i think you might be opening a can of worms,there will probally be alot of fab to do,if you can do that then cool,if not i would just find a second hand megasquit,i saw one for 150quid and it had come off a zetec.
if you do this make sure you get the map one and not tps,
ZetecNology - 6/8/09 at 06:37 PM
Not using the car as a donor mate just the turbo components to turbo my zetec. Currently im running a zetec but fancy some boost
Yeah im gonna fabricate some plates to mount the inlet outlet manifold etc, ports are very similar on cvh and zetec.
The mans bringing all the parts down for me (700 mile round trip) so i have to send him a list of what to bring..
Heres my list so far..
T3 Turbo
-31 actuator
Intercooler
Inlet mani with charge carrier + throt bod
zorst mani
Fuel rail and injectors
Ofac ecu and loom with all sensors
Fuel reg
Boost hoses n vac pipes
oil feed/return?
fuel pump? (is it in tank on fiesta??)
Have i missed anything? Dont wanna end up going to build my zetec turbo then realise im missing something from the fiesta.. Cheers
RAYLEE29 - 6/8/09 at 07:12 PM
not too familiar with the fiesta turbo but i do know escort turbos if theyre the same youll also need the metering unit, cold start injector both ecu's and most of the engine loom
Ray
ss1turbo - 7/8/09 at 08:35 AM
I'm assuming that the Fiesta in question has already had the T3 upgrade and not running the stock T2!
If so, that looks like the shopping list - both engines have the pickup in the back of the flywheel, so should be fine to use your Zetec one.
MAP sensor is one you've forgot (or is that included in "all sensors"?). Be good to get the exhaust downpipe as a start, as well.
Pump is "in tank" on a Fiesta..
ZetecNology - 7/8/09 at 09:05 AM
Yeah im getting the old t2 and a new t3 that he was gonna upgrade it with
Yeah map sensor is good to specified aswell as sensors.
Downpipes a good idea
And i had a feeling the pump would be intank... Cheers for the help just making sure im not gonna miss out, as im not %100 clued up with fiesta turbos!
