posted on 12/1/07 at 09:26 PM
I just can’t get it out my head that all the SVA, DVLA stuff is not just a load of nonsense.
After all you only need the logbook to get your road tax. Even then do they have a look at your car to check it matches the car in question? Nope.
Do you need a photo if your car to show them? Nope
Do you need the logbook to get an MOT? Nope
Does it make any difference to your insurance if your log book says Escort or Locost? Nope.
Indeed how many folk have sent their logbooks off obligingly, expecting to see their new car called something different to an Escort or Sierra. Only
to find the sods haven’t change it at all? I know I have and yes I’m still annoyed at all the hassle I went through.
Even worse when its down as a 4 seater and I arrive at the MOT garage with 2 seats and not even a eyebrow is raised. I think to myself why oh why did
I bother!
But then I should not be surprised really since I have had quite a few cars that I ditched the back seats to get better performance and never had any
problems getting them tested either.
So yes I do wonder if I should just go and buy a £20 basket case and use its details for my car and forget this whole SVA testing lark altogether.
Oh well, sigh, that’s me had my rant now…right I’m off out to the garage to hit something.
Slightly off subject, but my Sylva Striker is still registered as an Escort. It doesn't really matter as I don't use it on the road anymore. But could I put it back on the road if I wanted to? Legally that is.
as a tester if i was presented with a locost that was listed on the database as an escort or ford etc ,i should amend the details to what i am presented with , this then flags a discrepency at dvla who should and are following them up. I have personally tested a Robin Hood s7 still registerd as a "cortina convertible", but don't know if dvla have been in touch with him (i did explain that they may follow it up)
Many years ago I tested a Sierra. I wrote out a failure on it and one of the things I failed it on was having TWO chassis numbers. The normal 17 digit
number on the bonnet slam panel, AND an 18 digit number on the floor beside the drivers seat.
We never did see the car back in our depot ( I believe he got it tested elsewhere). Several months later I received a verbal bol-- Reprimand from the
local area VI chap telling me that I should have just passed and advised, EVEN though it was clearly listed as reason for
failure.
Just a quick thanks to IanK. That link explained a lot, and I've just checked I've got MOT's back to 1993 describing my car a as a Silva Striker. So I'll give it a try. Cheers.
I got mine registered as a Bickell Designs, F1-2.
I just put myself down as the manufacturer and provided a reciept for the steel.
You need 8 points for an age related plate and a brand new chassis count as 5 points.
surely it cant be any more difficult to get it through SVA and correctly registered than buying and old car and transfering the ID and having you kit
car registed as an escort/cortina/dutton or whatever you buy
I see the SVA as another stage in the build and then at least i have piece of mind knowing that what i have built is roadworthy and safe to use
tyring to avoid SVA on a new build is wrong in my opinion as it was put in place for a reason
Thanks Antony
no offence meant to anyone this is just what i think
Something was wrong on my log book so I just ammended it, put a letter in with it and sent it to the dvla, came back with the details changed.
Rich.
Originally posted by jollygreengiant
Many years ago I tested a Sierra. I wrote out a failure on it and one of the things I failed it on was having TWO chassis numbers. The normal 17 digit number on the bonnet slam panel, AND an 18 digit number on the floor beside the drivers seat.
We never did see the car back in our depot ( I believe he got it tested elsewhere). Several months later I received a verbal bol-- Reprimand from the local area VI chap telling me that I should have just passed and advised, EVEN though it was clearly listed as reason for failure.![]()
all sierras have the number on the slam panel and on the floor by the seat, in fact i thought all fords did full stop.
well yes obviously, but there was no implication that they were different was there.....
ar yes, now I see, 18 digit and 17digit!!
