First thanks to chrisw for prompt reply to my u2u regarding the following:
I have the chance of a stripped Sierra 2 ltr OHC with ancilliaries.(Due to lack of space this is an answer to a pray if everything available). Chris
has provided a list of things that need to be part of the deal but has suggested appealing to the forum in case he has forgotten anything.
Engine,Gearbox, clutch
Rear diff, half shafts, hubs, hub carriers, calipers/drums
Steering rack, column, downlink, and switches
front hubs and calipers
prop
loom
instrument cluster......
Anything else I need to scour this chaps garage for?????
Many thanks guys!!! The dream is getting ever closer!!!
Andy P
maybe the v5 and chassis number to make things a bit smoother at the other end. Pretty comprehensive apart from that i think!
Fuel sender, cut off switch, if injection - the pump and filter. If it has alloys - get the wheel nuts - they are special.
And most important - the V5, any old MoT's etc
Mark
Other bits
Master cylinder
Hand brake & cable if OK
Steering Wheel (for SVA)
Speedo cable plus any others you can get
Rear View Mirror
Plus any nut and bolts you can get
Gordon
pedals assembly ?
steering column
ignition key?
horn
rear diff long bolts
starter motor
engine wiring loom - with cotrol unit
brake balance valve thingy
gear stick
HTH
thanks lads, I will check it out on saturday and let u know wot i got ...
ALL THE BEST
ANDY P
The battery might be useful for your first power up
Old headlinings are great for lying on if your work area is not a nice heated clean garage!
