Hi can any one help. I have an MK indy with a Hayabusa engine. I am using the bike loom extended but not the original air box. The F1 light on the
dash is lit and I can not get it to fire up. This is the first time I have tried it in the car but all was fine in the bike. I have fuel being pumped,
any ideas please
Adrian
it means something is wrong with a crucial sensor.
Search in the hayness how to put it in error mode with codes you can then see what the problem is.
else check: spark, injectors, maps sensors and temp sensors..
Tks
ats and the coolant temp sensor need to be plugged in or you will get default coolant temp of 80c and you will see the fuel going in but not enought to start it, had the same prob with my tl motor
and don't forget to jump the side stand switch, my mate wasted hours wondering why his car was cutting out when he put it into gear!
Ned.
It looks like you are getting some help, but I would have suggested you'd do better, in the "engine and transmission" or
"bec" sections rather than here.
You are always welcome here for a look around and brew of course...
