Velocity questions
Rubin - 14/4/09 at 10:28 AM
Unfortunately had an off and have damaged my velocity.
I need some new bodywork so looked back thru my Luego info for the RAL colour but all I have is that it is "Luego Orange" - anyone know the RAL code ? pic attached if that helps
Also need a rear camber adjuster - can I only get these from Luego or are they off the shelf anywhere ?
bill132hotrod - 14/4/09 at 10:58 AM
Go to Luego website the have a colour chart and also i think its only Luego that make the offset mushroom top hat.
Good Luck.
Rubin - 14/4/09 at 11:20 AM
thanks, couldn't see the colour selector at first but found an old link - it's RAL 2003
On the camber adjuster it's the rear one i'm after not mushroom on front - i'll give luego a call later today
thanks again
Sebastian - 14/4/09 at 11:56 AM
If you are going to order new bodywork i would ask about the colours they are using now, because i heard that he has switched suppliers.
Unless you got the current bodywork also from Ben.
