So, following the various threads of advice on the forum I stripped down the rear 'bones, cleaned the powder coat from the ends of the wishbone
tubes, cleaned and polished the crush tubes with W&D paper, re-assembled with lots of white lithium grease - different squeaks, but still
squeaky......
Are we missing the point ? Are the wishbone tubes too tight ? When I assemble the crush tubes into the bushes outside the wishbones they are a good
sliding fit, but once the bushes are in the 'bones the crush tubes need pressing in with a fair bit of force......
Simon
Am talking to Superflex next...
Simon
Had a similar issue with mine. I fitted the poly bushes, then used a 19.0mm reamer to open the hole again so that the crush tube was a good sliding
fit. No more squeaks!
Ed.
The other aspect to check is the crush tube length against the outside faces of the fitted bushes. i.e. measure the fully fitted bushes face to face
(with a vernier is easiest) then check the length of the corresponding crush tube. The crush tube needs to be ever so slightly longer (~0.5mm) so
that when the wishbone is bolted in place the bushes are not "clamped" by the faces of the wishbone bracket. NB - too much over length on
the crush tubes and you'll get unwanted fore/aft movement of the wishbones. Also, it's worth checking each set of fitted bushes and each
crush tube - don't meaure one and assume they'll all be the same. Finally, make sure you grease the outer faces of the fitted bushes where
they will rotate against the wishbone bracket.
(I hope I'm not teaching you to suck eggs here BTW - just offering what I learnt building mine)
This sort of problem makes matalastic bushes a good thing to use.
My Indy is the same. I think the bushes are too tight, but haven't got round to doing anything about it yet! It's only been on the road for
3 years!
[Edited on 5/7/10 by whitestu]
Originally posted by nick205
The other aspect to check is the crush tube length against the outside faces of the fitted bushes. i.e. measure the fully fitted bushes face to face (with a vernier is easiest) then check the length of the corresponding crush tube. The crush tube needs to be ever so slightly longer (~0.5mm) so that when the wishbone is bolted in place the bushes are not "clamped" by the faces of the wishbone bracket. NB - too much over length on the crush tubes and you'll get unwanted fore/aft movement of the wishbones. Also, it's worth checking each set of fitted bushes and each crush tube - don't meaure one and assume they'll all be the same. Finally, make sure you grease the outer faces of the fitted bushes where they will rotate against the wishbone bracket.
Hi
" This is a Luego specific problem, that to mu knowledge does not happen with other kits. ie all down to the crush tube being a bit short.
Saying it is a Luego specific problem is very misleading. Having 4-5 cars through the workshop every week from virtually all kit manufacturers it is
fair to say that all those using these cheap bushes have the same issues. Simply by measuring the outer wishbone housing and the difference in the
bushes and the length of the inner pivot tubes it is quite clear that there is quite a tolerance to be found on all dimensions on all manufacturers
cars using these bushes.
Might not be a bad idea to have all these different threads regarding this bushing problems collated in to one there's currently three threads
running if proof was needed how bad things are.
Cheers Matt
Yup - mine's not a Luego, and in fact my crush tubes were a little bit too long so they had to be shortened. I think it's a fairly common
issue across all manufacturers...
Ed.
Thanks all for your comments and suggestions. I only measured one assembly (assumed they would all be the same ... dohhh !). Crush tube is 42.12mm,
built up polybushes in the wishbone (powder coat cleaned off) measure 41.59mm, almost exactly the 0.5mm suggested as the right clearance. Am tempted
to go with a 19mm reamer and see how I get on with, replacing the bush assemblies with better ones with stainless crush tubes as the next guess. Any
suggestions for well made bush kits in the Luego size would be welcome - I'm going to do a bit of a search of a few of the sites now to see if
any of the stock sizes look right.
Thanks all
Simon
Let us know what you find as I need to replace mine, they are driving me mad.
I took the Velocity to Le Mans for the weekend and was embarrassed every time I drove the car anywhere, it squeaked so loud. I have to get this
sorted. I am going to change the crush tubes and bushes but not sure what to go for and would appreciate advice here. I know Superflex do bushes
that appear to be high quality but they work out at several hundred pounds a set which is too heavy.
So, any idea if a set of bushes can be bought that are not too expensive but are better than the standard rigid plastic things I have now?
