Front wheel arches
Gasgeek - 14/4/16 at 10:53 PM
Hi
Can any body recommend a good adhesive to bond my wheel arches to the brackets
my old ones where bolted on that's cause cracks and crazing in the gelcoat.
ReMan - 14/4/16 at 11:21 PM
sikaflex
Is most commonly used
Very sticky and flexes, make sure and key well with super rough sandpaper on the wings and stays
CosKev3 - 15/4/16 at 07:20 AM
As above,any polyurethane adhesive will be ok.
Tiger Seal is quite a common,but expensive one in motor factors.
If your brackets are flat bar drill some holes in them for the adhesive to go into,as well as keying and degreasing both surfaces
[Edited on 15/4/16 by CosKev3]
Gasgeek - 15/4/16 at 07:58 AM
Thanks for the advice guys
benchmark51 - 15/4/16 at 08:01 AM
That's how I do it, but I weld plate on to the bracket and grind it flat to make the adhesive 'footprint' bigger
mcerd1 - 15/4/16 at 08:42 AM
Würth 'bond and seal' is another decent PU
Most decent builders merchants should have one of these or a good alternative
[Edited on 15/4/2016 by mcerd1]
Greenie - 15/4/16 at 07:02 PM
I have just secured mine with sikaflex, works a treat, but said, make sure the brackets are clean and rough up fir a good key.
twybrow - 15/4/16 at 08:06 PM
I glassed on some captive nuts (rivnuts used like Big Heads) which means I can unbolt my arches in a minute or so. Very handy and secure.
