Hi everyone.
Does anyone know what size poly bushes are required for a velocity xt.
I have taken one out and measured 42mm long but can’t seem to find any that size ?
Thanks in advance.
I don't think they have to be exactly that length. So long as they both fit and the diameter is correct, a few mm either way inside the tube won't make any difference.
Agree in principle with Mr Whippy here it's the inner and outer Ø fit on the crush tube and wishbone that's more important than the exact length of them.
Whichever poly bushes you choose make sure the crush tube is long enough for the job. Crush tube issue is a well known problem , I suspect a lot of wishbone failures are down to it?
stainless being the best but rare. Plenty of grease is a good solution and I like packing the gap between the bushes before inserting the tube
That sounds rude but isn't meant to be
Day late and a dollar short - but for future reference.
From my XT they are:
45mm long and a 29 mm diameter polybush.
I picked up these to replace a damaged one.
https://www.duraflexpubushes.com/haynes-roadster-locost-wishbone-bush-pair-42-p.asp
Oh and defo had to use large washers to shim the wishbone to the mount size correctly - shout if you need a photo!
[Edited on 19/1/23 by Gersen]
