Velocity XT Rear Hub (Drum Brakes)
Ferg - 10/7/05 at 05:30 PM
Has anyone assembled these rear uprights and hubs???? Luego suggest that the backplate is spaced off the upright (because of the shape of the backplate) with washers, but I have shown a spacer on my (playgroup style)drawing. Due to the way the shaft outer joint sits the hole in the upright is a good 4-5 mm too small since the shaft MUST go though to a certain extent. Has anyone made this hole bigger...or are our shafts a bigger diameter???
All advice gratefully received, I can tell you........
tks - 10/7/05 at 09:17 PM
guess
what you try to is right...
measure up the hole and your shaft..
surely one of us can come up with the righ measure ment?
Mark18 - 11/7/05 at 02:43 PM
The shafts on the 3.14 diff I had were strangely slightly bigger - I'd never heard of any mention of this before, but maybe your shafts are the same? Regardless, I can't see any reason not to make the hole bigger if the shafts wont fit.
Mark
