Can any one tell me the height of a velocity scuttle and a locost scuttle please.
also. Does anyone know if the velocity body work will fit a locost chassis..
Yes I think they are interchangeable, my velocity chassis measures up to the 'book', evern thou I have inderpendant springy bits. The Luego bonnet and skuttle are taller to accomodate modern engines . The crossflow only just slid under a locost bonnet leaving the air filter behind.
Thanks mate. do you know how high the velocity scuttle is?
Im trying to squeeze a zetec under the bonnet and lot under the scuttle.
Sorry i cant help you. Try Grant at Luego, I found him prity helpful. I am after a similar dim to fit a duratec under the hood.
My Velocity scuttle is 310mm high.
I've got a Zetec fitted in, using the Velocity XT chassis & bodywork. Its a bit tight at the nose cone end but fits OK.
Thatnks chaps. Ive gotta get some parts from grant so will have a chat then..
