Steering rack rubbers
rickys2000 - 11/5/06 at 05:51 PM
Hi Guys
Does anyone know the part number for the mounting rubbers for the Luego supplied Escort rack for my Viento?
Ricky
simonk - 12/5/06 at 01:16 PM
I went to a BIG Ford dealer and went through the parts computer with the parts man until we found the right bits - you'll need a helpful parts man and a quiet day. They also had the steel clamps. Other option is Demon Tweeks and possibly Rally Design, who I think do compatible alloy solid mounts. Pretty, but more expensive. Best of luck.
Simon
kitcarkris - 12/5/06 at 03:12 PM
i took my steering rack along to a brakers and tried loads of rubber one suntil i found two that fit, took an hour but dirt cheep!best of luck
bob0112 - 12/5/06 at 06:07 PM
brought mine from a stall at delting show ground Poly race part no sf932. these are a polyurethane bush
bob0112 - 12/5/06 at 06:29 PM
http://www.motoscope-online.co.uk/products.htm
a site that is worth a look for MK1&2 escort part. bushes are listed on the site bit are a bit more exspensive than paid at the show.
RichB - 16/5/06 at 11:53 AM
I just got some from Rally Design for my velocity: less than a tenner and allegedly better than the originals.
rickys2000 - 16/5/06 at 07:54 PM
Thanks for the help guys.
RichB, do you have the part number of the rubbers you got from Rally Design you can let me have please
thanks
Ricky
RichB - 16/5/06 at 09:28 PM
Ricky
I've just checked my invoice and they are part number RD822 and a wopping £2.90 (+VAT) for the pair!!! These are h/d rubber.
I've just seen in the catalogue that they also do a polyurethane set for £6.10 (+VAT) PB932.
I'm sure the ones i've got will be fine (they say they are increased grade rubber) but if i'd seen the other ones i would probably have got them.
I'm such a catalogue geek!
rickys2000 - 18/5/06 at 08:37 PM
Cheers Rich
