Velocity clutch cable
Stewart Kimber - 31/5/06 at 09:05 PM
Silly question but can anyone advise on type of spring for clutch cable to pedal. Build manual just says 65mm spring. Presumably that is an expansion spring.
wicket - 31/5/06 at 10:01 PM
Its a compression spring
jcs - 8/6/06 at 09:59 PM
If its any help I used a cut down throttle return spring from a sierra carb.
Peteff - 14/6/06 at 12:06 PM
I find some handy springs in old car seats when I go scrounging in the scrapyard. What spring you need depends which side of the pivot point you put it.
