SVA - wish me luck
Paul (Notts) - 10/2/08 at 06:39 PM
Oh well, the big day has finally arrived. Spend today trying to finish off 10 jobs and found another 20.
The only real problem is that I cant find the certificate that proves the pipes going from the master res to the brake cylinders is suitable for brake fluid. Will look again latter.
Wish me luck.
Paul
tjoh84 - 10/2/08 at 06:55 PM
good luck have fun
[Edited on 062929p://5523 by tjoh84]
bigrich - 10/2/08 at 06:56 PM
Good Luck
but I'm sure you won't need it
Rich
sammy - 10/2/08 at 06:57 PM
Good luck!
Wish I was close to getting SVA, so much to do...
speedyxjs - 10/2/08 at 06:59 PM
Good luck
Yours is one of the best looking sevenesque cars iv seen
piddy - 10/2/08 at 07:22 PM
Good luck. I'm sure you'll sail through it.
NeilP - 10/2/08 at 07:32 PM
Best o' luck Paul - Sure you'll be fine - Look forward to another bonkers Viento on the roads in the Midlands...
jollygreengiant - 10/2/08 at 07:34 PM
You will be fine, just have faith in your own abilities.
richard thomas - 10/2/08 at 07:48 PM
Good luck Fella!!
dave1888 - 10/2/08 at 08:54 PM
Good Luck
locoR1 - 10/2/08 at 09:13 PM
You will be fine!
Not that you’ll need it but Good luck anyway!
LBMEFM - 10/2/08 at 09:14 PM
Good luck, I wish mine was that near completion, hope the weather keeps fine.
Barry
rusty nuts - 10/2/08 at 09:23 PM
Break a leg as they say. If the master cylinder hoses are the blue stuff they may have a part number on them so you should be OK.
madteg - 10/2/08 at 10:54 PM
GOOD LUCK dont forget the tie wraps and black tape.
ditchlewis - 11/2/08 at 09:11 AM
Good Luck and enjoy the experience.
ditch
