Gear Change Extension
Numb nuts - 3/10/08 at 02:03 PM
I have just bought a gear change extension for my type 9 in my velocity. It didn't come with any instructions.
Can anyone help please?
Mr Whippy - 3/10/08 at 02:45 PM
what a gear shift leaver?
there's just 3 bolts and it falls off, put it in neutral before to make it simple.
modee - 3/10/08 at 02:57 PM
If it is the Rally Design/ Westfield type you will need to swap the plastic bush that the lever fork sits on from the box to the extension.
Numb nuts - 3/10/08 at 05:35 PM
Thanks guys...I feel a right berk...had I have realised it was that simple I wouldn't have posted this request!!
jollygreengiant - 3/10/08 at 05:51 PM
When you fit it, just make sure that the propshaft clears it with the gearstick fitted.
I got an extension, then I got a propshaft and the prop doesn't clear the assembly due to having heavy duty u/j's fitted to cater for later engine upgrades.
