Do you actually have to have one? Maybe I'm being blind, but I can't see any reference to it in the IVA! Are there specifications for
it's construction, size location, etc?
The reason I ask is that there may be an issue with visibility, so for the test I could raise the seat up, so that the arches fall out
of the plane of view, but then the roll hoop would be level with the top of the drivers (my!) head - less than ideal in a roll!
Just SVA/IVA without it and put it on after
TTBOMK there is no requirement for a roll hoop at all for SVA & presumably will be similar for BIVA - I think you are worrying yourself excessively about the view of the road ahead - there are plenty of both kit & mainstraeam cars where the front of the car intrudes into your vision, depends on how you read the manual.
If you do not attach a safety harness to the hoop, it is cosmetical only. If you add some padding to prevent injury from head-on collission, I
don't see any problems with the hoop being too low. THE QUESTION IS: DO YOU WANT IT???
Even when you lower your seat a bit after the test, will there be enough visibility? Moreover, you can better have a hoop being a couple of inches
taller than the top of your racing helmet.
See this thread.
Your chassis looks btw!
Originally posted by maartenromijn
If you do not attach a safety harness to the hoop, it is cosmetical only. If you add some padding to prevent injury from head-on collission, I don't see any problems with the hoop being too low. THE QUESTION IS: DO YOU WANT IT???
Even when you lower your seat a bit after the test, will there be enough visibility? Moreover, you can better have a hoop being a couple of inches taller than the top of your racing helmet.
See this thread.
If you want to lower your seats after the test, I'd just tell IVA that the hoop is cosmetic. Do ad some padding.
Are you going to IVA it with or without body? Or will you put your head trough the sunroof when your seats are higher for the test??
