Hi All,
As per title really, I gather that for SVA the wiring has to be clipped every 30cm, Brake lines need to be "secure", but what about fuel
lines?
I've done a quick search and can't find it - Sorry If I have missed it..
Thanks as allways....
Not stated for fuel (or brake) lines.
Stick with max of 300mm and you'll be fine.
adrian
Thanks for the quick reply Adrian.
Kevin
make sure the rubber fuel pipe is suitably marked a lot of test centres now require proof from manufacturer as to suitability, I thought it was daft at first but thinking about it the tester is certifying your car as fit for the road if the fuel pipe splits cos you've used low pressure pipe in a high pressure system and the car explodes technicaly he could be liable
