fog light
markyb - 25/3/09 at 02:17 PM
I accidentally broke my fog light and ordered a new one off tinterent but they sent me a stop/tail one instead
probably a bit of a numpty question but, if I changed the connections and bulb, would it do the same job as a fog light
I know the chances of driving in fog are probably slim but the car has still to go through SVA so need it to be correct
thanks
adithorp - 25/3/09 at 02:23 PM
Proper fog light has a narrower beam giving higher intensity (same 21w bulb).
maximill666 - 25/3/09 at 04:06 PM
It would fail SVA as the SVA Inspector will be looking for the light lens to be marked with an 'F' to indicate the lens is a fog light.
Hellfire - 25/3/09 at 05:36 PM
Usually the Fog light has a reflective moulding as opposed to a typical satin finish.
Hellfire - 25/3/09 at 05:37 PM
If you're pushed for time, could you not repair the fog light you've damaged? (Providing it isn't beyond repair)
Phil
markyb - 25/3/09 at 06:50 PM
had a look at the light and there is no 'F' on it so have got onto the supplier ref a replacement.
I didnt realise that the light was letter coded - you learn something new everyday
