Getting nervous about the re-test, 1, I am using the standard carb settings with the Fireblade airbox and the large MK silencer with the cat fitted. Do you think emissions will be OK as I cannot prove that my engine is the pre 95' cut off date. 2, As mentioned I have fitted the large MK silencer, it still sounds quite loud, how do you re-pack it to make it quieter? If you have some suggestions I will feel a lot more confident. Cheers Barry
Did you not get the letter from Honda yet?
I understand it will be tricky, (but not impossible) passing emmisions on post 95 spec elsewise
Honda said it could take up to six weeks to get the information, as this would be too late for the re-test I thought I would try it first without.
Stuff a load to wire wool up the exhaust!
Write your own bloomin letter!
For the risk of £50 restest I'd be on the Honda website getting the logo!
it's only £38 retest
