am getting to the stage where i need to start thinking about finalising bodywork,mirrors,lighting etc! so here goes;
1; are there any iva friendly mirrors which are cage/roll bar mounted? and a link if possible
2; are the twin hella type headlight units (as on the sdr storm) iva ok? and again a link please
3; is there any decent rubber edge trim for front arches etc as the stuff i had wont bend to a tight radius and just looks a bit crappy?
4; is there any alternatives to the ally/stainless fuel filler caps? possibly a bit cheaper.
5;can i use rubber fuel hose for the whole install or do i need to run copper then rubber at each end? and a link to iva friendly hose please.
thanks. dan
Answer to question 4. not ali or stainless but IVA friendly,cheap and over comes the rear panel to tank problem.
Locking Fuel Cap & Angled Neck, Black ABS, Vented on eBay (end time 08-Jan-11 17:08:47 GMT)
I have one of those, ^^^^, fitted, and apart from the weird way they lock and unlock, just great, and much less dosh than the ally ones. Cheers Ray
3. I used CBS rubber U channel stuck on with sikaflex/tigerseal
5. I used 10mm microbore copper central heating pipe and used marked rubber fuel pipe from Halfords to connect + the proper fuel clips
Yes you can use rubber fuel hose for the whole install, acording to a supplier I asked at a kit car show trade stand.
