Rear fog light again
axle - 5/12/13 at 08:53 PM
Hi all
There has been lenghty discussion about this on the forum previosly and I thought if the fog light was only operate with ignition swith on with deep / main beam it would be ok, but than I find this part from CBS. Am I going to be ok or do I have to fit this?
http://www.carbuildersolutions.com/uk/rear-fog-controller-for-new-iva-rules?utm_source=Newsletter&utm_campaign=6ff1a02865-RSS_EMAIL_CAMPAIGN&u tm_medium=email&utm_term=0_5af799d590-6ff1a02865-86608101
Please help?
big-vee-twin - 5/12/13 at 09:31 PM
Either that or 5 quid for a buzzer and relay.
loggyboy - 5/12/13 at 09:33 PM
Call you local vosa office and speak to the examiner. If your not due to take itvor a while hold off as I suspect this will be something that will either be clarified or removed in the next revision.
40inches - 5/12/13 at 09:40 PM
Wot he said
davidimurray - 5/12/13 at 09:41 PM
As above, my examiner last month said the on/off buzzer is only applicable if your fog light can be switched on with sidelights. If you wire it so they only work with dipped/full beam then they don't need a buzzer/door interlock.
axle - 6/12/13 at 09:29 AM
Hi all
I am very grateful and relived many thanks to everyone’s contribution.
Thanks again
CosKev3 - 6/12/13 at 06:56 PM
Not all testers say this,I know a car thats failed for having the fog light like this.
Also Westfield are now starting to make there looms for the new way the foglight must work.
Some light switches,like mine in the VRS,will physically turn off the fog lights when you turn off the headlights,could be another option instead of expensive control boxes/extra wiring
jacko - 6/12/13 at 09:07 PM
Not IVA but what is the light for on the fog light switch ? i thought it was to let you know the fog lights are on
loggyboy - 6/12/13 at 10:16 PM
But thats based on having a sensible driver, they let any dimwit have a license.
Agree with the above comments, I think the note is clear enough that you do need either a buzzer or a system to switch them off, regardless of if they are switched by the fr8nt fog/side light combo.
Acc8braman - 7/12/13 at 05:34 AM
Depends when you want to IVA it, if this year you will most probably get away with it.
If not, you will need to make sure if you turn your ignition on and you have left your fogs on, they do not come on.
I had a test a week ago and was not tested
I have a spare cartek one if you need it and open to offers?
The Black Flash - 8/12/13 at 11:42 PM
this thread on PH is suggesting that the rule is about to be dropped, matching what Loggy said above.
Dunno how true it is mind!
[Edited on 8/12/13 by The Black Flash]
