Hi all,
Its been a while since i have posted here, I'm currently battling my way through trying to register my locost here in Spain. It passed its IVA
last year with flying colours, with a 2.0L Pinto, R1 carbs and megajolt, and I got a Q plate. Trouble is, they don't recognise cars by their
engine age here in Spain so they need to check emissions as if it were a new car (or at least at the date of its registration, which is 2017)
Im trying to tell them that wanting to test a pinto at the current standards is like asking an old Commodore to run Windows 10, but I'm not
winning that battle as far as I can tell. So i was wondering, if i tune the carbs as best i can with my wideband, run the engine as lean as possible,
fit a 400 cell cat and use a special "MOT" map, maybe even have it run on 3 cylinders just for the test?
I dont mind if I shorten the cat's life considerably doing this... its just to get me through this ridiculous test.
IIRC the current standards are:
CO: 0.2%
HC: 200ppm
Lambda 0.97-1.03
Is there any chance i can get the old boat anchor through the emissions test? Or would i be wasting my time (and money)?
Thanks!!
Tom
[Edited on 14/6/18 by robertst]
There was a bit of kit available some years ago that would do what you want, I don't believe still available, but must be possible to get the
requisite circuit made up.
Basically you set the carbs to run slightly rich at whatever throttle openings are required, eg at idle & at 3000 rpm, you then have an vacuum
take off on all carbs/inlets, these are all connected to a solenoid controlled valve which can leak air when required, the solenoid is controlled by a
lambda sensor which works in the usual way, so when it senses rich you need a circuit to open the solenoid & bleed air, as soon as the lambda
sensor senses weak it closes the valve & with the air bleed cut off it will tend rich again.
It would need some playing with but can't see why it wouldn't work
I put a Toyota 4AGE in with it's standard fuel injection on (ok admittedly injection rather than carbs, but a bog standard 22 year old engine)
& it would have passed the CAT test (even tho' it had no CAT fitted!) with the exception of the lambda reading!
Lambda is by far the hardest thing to get stable, they give you such a small "window" - with the ZZR1400 engine we don't use a lambda
sensor, but simply set the map to give the right fuelling at idle & 3000, never failed to get one thro yet
I suspect you will only want to be fractionally rich & have only a very small air leak with the solenoid, but the theory works ............
Best of luck
I don’t think it can be practically done at home on carbs. Even running it hot with air injection.
You need a lean burn 16v engine with fuel injection and a cat. All in my opinion and happy to be wrong.
[Edited on 14/6/18 by big_wasa]
Originally posted by russbost
There was a bit of kit available some years ago that would do what you want, I don't believe still available, but must be possible to get the requisite circuit made up.
Basically you set the carbs to run slightly rich at whatever throttle openings are required, eg at idle & at 3000 rpm, you then have an vacuum take off on all carbs/inlets, these are all connected to a solenoid controlled valve which can leak air when required, the solenoid is controlled by a lambda sensor which works in the usual way, so when it senses rich you need a circuit to open the solenoid & bleed air, as soon as the lambda sensor senses weak it closes the valve & with the air bleed cut off it will tend rich again.
I put a Toyota 4AGE in with it's standard fuel injection on (ok admittedly injection rather than carbs, but a bog standard 22 year old engine) & it would have passed the CAT test (even tho' it had no CAT fitted!) with the exception of the lambda reading!
Lambda is by far the hardest thing to get stable, they give you such a small "window" - with the ZZR1400 engine we don't use a lambda sensor, but simply set the map to give the right fuelling at idle & 3000, never failed to get one thro yet
Best of luck
Originally posted by big_wasa
I don’t think it can be practically done at home on carbs. Even running it hot with air injection. You need a lean burn 16v engine with fuel injection and a cat. All in my opinion and happy to be wrong.
What Russ has menchioned is I believe air injection. It’s nothing new but not easy to control. The cat won’t last long with carbs and it’s a dance you will have to do every year
"it’s a dance you will have to do every year" - certainly worth bearing in mind if that's the case - how does "MoT" work in Spain, what limits would they test to? Can you find a "friendly" Spanish garage?
Its running pretty well for now, When it was tested it was below 2% CO and HCs were at around 900 i think, so it passed with room to spare!
As regards an engine swap, would an injected Mx5 lump not be the easiest option? Can you get the standard injection system under a 7 bonnet? If so that would make a relatively simple swap rather than needing to go the bespoke injection & ECU route
LoL as you can see I'm not an expert on 7's!
The test might make things a more complex depending on the combination of tests that is done.
In Ireland the emissions is checked at idle for HC and CO.
And again at 2-3,000 rpm
HC, CO and lambda.
Would suggest is impossible to get it pass all 5 tests with carbs.
An Efi system complete for a modern car after 1994 and a cat might get it through testing but might run like a pig.
As in a fiat 1.2 single point injection throttle body, it’s ecu, it’s cat and exhaust o2 sensor.
The cat will burn fuel the engine doesn’t burn properly and the ecu will get it to pass the lambda test.
If your engine is burning oil try a different approach as you will fail HC.
Any exemptions for hybrids, 2 strokes, registered electric etc available?
I used what russ was suggesting to get through my emissions. It had a control module and two valves which were connected to the inlets just below the
carbs (fireblade )
It was very easy to setup as you just set it up normally, richen it up till a light came on then switched the unit on. Went through emission easy,
Amalyos on here also got through sva using it also.
I bought it from Fisher sports cars then sold it on here. Haven't seen it advertised since.
Pete
Originally posted by robertst
Actually, the Mx-5 is a good alternative! nice rorty little engine, but i'd still have to get a new bellhousing to fit it to the type 9 or get a mazda gearbox and a new custom made propshaft to connect it to the diff, and a megasquirt to get it to pass emissions anyway, not to mention the inlet and exhausts are the other way round than on the pinto, so i'd have to change lots of other bits in the engine bay...
Guys, let's get a few things straight, if we're talking about a knackered Pinto with 80,000 miles that's breathing oil & has carbs
on it that aren't setup properly then, no, absolutely no chance of realistically being able to get it to pass, but I used to work on Pintos all
the time back in the day, our speciality was Crypton Tuning (remember those?), we used to get the ones to straighten out after everyone else had had a
go & screwed them up!
Providing the engine wasn't just plain knackered, then, with valve clearances set correctly, new filters, breathers clear & working as they
should, the engine was easily capable of 1% CO & less than 200ppm HC's, & running like that fuel/air would have been close to 14.7:1 -
I'm not speculating, those are hard facts, now I don't know just how the bike carbs are likely to affect that (tho' wouldn't be
hard to bolt a 28/36 Weber or similar back on), but as long as they are giving a linear mixture, ie not way weak or rich at either end of the scale,
& remember, 3000 rpm is a very small throttle opening with no load, it's only just off idle, then it should not be hard to get it passed if a
similar kit to that which has been described can be either purchased or assembled
As a matter of interest does anyone that actually had one of the professionally supplied ones remember the name - you never know what may be available
on Ebay!
Originally posted by watsonpj
I used what russ was suggesting to get through my emissions. It had a control module and two valves which were connected to the inlets just below the carbs (fireblade )
It was very easy to setup as you just set it up normally, richen it up till a light came on then switched the unit on. Went through emission easy, Amalyos on here also got through sva using it also.
Pete
HC, CO and lambda.
Originally posted by mcerd1
I do love the my pinto - but asking it to pass modern emissions on carb's sounds like too much work, so I'd say if your going to need to do all that work then you might aswell do it to a more modern engine...
A duratec HE (1.8 / 2.0 / 2.3) has the exhaust on the same side as the pinto
type 9 bellhousings are easy to get too not to mention the extra tuning potential
and its a similar story with the ford sigma (aka Zetec SE) engine (1.25/1.4/1.6/1.7) - these are cheap and easy to find, very light next to a pinto and some folk have even got these running on the stock Ford EFI too
Pretty sure there were no changes on the bottom end between carb & injection models. There may have been minor changes to the head or valves, but
pretty sure cam was the same, if you're running a wild cam then it will make the exercise harder, but not impossible.
The big changes in later engines (like Zetec, Sigma & Duratec) with injection & combustion chamber shape etc were all about reducing NOxes not
CO & HC's
Another cheap and cheerful solution would be to fit a pinto injection head and all the EFI bits. Ford did make catalyzed injection pintos at the time, right? plus my pinto has the 205 block, which if im not mistaken was also used on the injection models..
Sounds like an application for a PIC controller. All you need is a PC programmer and a bit of assembler code. Maplin used to supply all the bits.
Pete
10/10 for effort you must love your pinto.
If the HC is high you might find replacing the valve stem oil seals will reduce them ? Easy to do without taking the head off. High HC is caused by unburnt fuel or oil. The more efficient an engine runs the lower the HCs , one of your earlier posts mentioned running on 3 cylinders which will may things worse.
That is some mightily impressive work there, well done!! Out of interest, how often do the solenoids switch on and off? Is it a click every so often or are they merrily buzzing along all the time? I'm guessing the Arduino can run significantly faster than the solenoids could keep up?
"My goal is to get it within 0.98 to 1.03 lambda, which is the limit here for emissions" well you're already there at 2500rpm, 0.99 to
1.01 is better than a lot of older production vehicles, do you need to have lambda checked at idle? In the UK it's only CO that's checked at
idle.
Assuming the lambda readout to be accurate then I would expect CO & HC's to be easily controlled with a CAT - hope all goes well with the
test.
Presumably the transistors you mention are used to take the output from the Arduino & switch the solenoids?
i dont know if this helps but:
in all EU member states (besides UK) the emmission standards are linked to the registration date.
thats why "newer" uk-kitcars cannot be imported anymore to other EU member states, as most cars do not even have a cat fitted.
this said, if you are a british-resident which has moved to spain or anywhere else inside the EU...you often can get away with an examption for the
emmissions as you can delcare the car as removal-goods.....in some member states this is possible, but its linked to the fact that you cannot sell the
car within the next 1 or 2 years ( to avoid that "dealers" use this loophole in the law to do profit).
unfortunately, in most countries the authorities wont tell you that option....you need to ask them or find the dedicated articlae of law and show
them.
also you need to consider that a 2017 car has to fullfill the EURO6 emmission standars. this standard is also linked to several other things...like
OBD connection, noise, EMC and so on....
sell the v5c back to uk and find one with an "older" reg-date.....not really legal, but much easier....
or sell the car back to UK and buy a car which is compliant with the EU reg / emmission laws....at the end of the day maybe a cheaper option
[Edited on 3/9/18 by alfas]
