Hi can this be made IVA compatible,
I will be in the same situation soon, still didnt do any research.
What if you wrap the exhaust including the O2 sensor?
I wrapped mine in exhaust heat shield and had no issues with IVA
Wrap it, IVA is only bothered with edges/radiuses. Not the 600degree exposed 5ft chunk of metal.
hmm why is the lambda sticking up like that?? would it not be better to move the fitting nut a couple of inches back and have it horizontally towards the car?
Is has to be in or just after the collector.
OK, how about just having it horizontally towards the car but still in the collector? Or on the corner, or even pointing downwards? Up just seems 'odd'.
Ok thanks everyone for the replies I think if I'm still using the same manifold could I cover it with something like this
