its car weighing time.Q16 of the sva form says the design weight of the car is "the weight including the load that the vehicle is capable of imposng on the road" is this the car, a full tank of fuel and two people, because it is a two seater,or is it just one person.once you have weighed the front and rear axles do you add these together for the gross or do you have to find a weighbridge.
IIRC the design weight of our's is 900Kg. Shouldn't all seven type type cars bought from a manufacturer be similar?
