wrapping loom & SVA
locoboy - 14/8/06 at 08:55 PM
Im stripping my loom open at the moment to do the cut and shut side of things.
I am planning on using the split convoluted tubing to carry the loom when its in the car but what should i wrap the wires in before putting it in the tubing?
I have heard that regular insulating tape is not favoured by SVA testers.
nitram38 - 14/8/06 at 09:15 PM
You can buy loom tape. It looks like insulation tape but it is not sticky.
It can be wrapped around the cables and secured each end with a little insulation tape.
I got mine from premier wiring.
I am not sure if you need to tape the cables if you are using flexible conduit as this will provide the necessary mechanical protection.
[Edited on 14/8/2006 by nitram38]
ReMan - 14/8/06 at 09:32 PM
You don't need to cover the cables, the tubing is enough, though a bit of loom tape or heatshrink of pvc sleeve is nice where the wires leave the tube.
