Quality of welding.
Anglia66 - 8/9/06 at 06:15 PM
How do they check the quality of the welding?
JoelP - 8/9/06 at 06:25 PM
looks alone unfortuantely. Not much else they can do cheap!
ch1ll1 - 8/9/06 at 06:27 PM
my father inlaws says they might hit it with a big hammer
but then hes not a full pack of cards
Danozeman - 8/9/06 at 07:40 PM
THey do crack tests etc on them. Ie hit it with a hammer and see if the weld breaks. Also cut the weld in half and see how far its penetrated..
Simon - 8/9/06 at 08:24 PM
They give a visual inspection. If you're concerned your welding isn't up to scratch (should we be too, as fellow road users?), I'd suggest getting it professional welded.
Simon
Anglia66 - 8/9/06 at 08:51 PM
With 26 years experience I'm not at all concerned about the quality of my own welding but was merely curious about how they tested it on a painted or powder coated chassis.
DIY Si - 8/9/06 at 08:53 PM
They're not allowed to destructievly test the chassis for a fairly obvious reason. A sample of your/the welding on the chassis may be better, but otherwise it's purely on looks!
thunderace - 8/9/06 at 09:56 PM
AN EASY WAY TO TELL IF USEING A MIG IS TO DO A LINE ON A 3MM PLATE AND TURN IT OVER IF YOU DONT HAVE AN EVEN BLUE ISH LINE ON IT YOU KNOW YOUR NOT DOING IT RIGHT AND DO A LAP JOINT USEING 2 BITS OF 3MM TACK ONE SIDE THEN WELD THE OTHER THEN DO THE OTHER PUT IN IN A VICE AND GIVE IT A KICKING IF IT CRACKS YOU HAVE A PROBLEM.OR DO A NIGHT COLLEGE COURSE.ITS CHEAP
DIY Si - 8/9/06 at 10:00 PM
NO NEED TO SHOUT!!!
