brakes...
A1 - 26/11/08 at 09:36 PM
just put the fluid in the system and bled each caliper individually, but the brakes are really spongey...ive got wilwoods on the front and sierras on the rear...
bigrich - 26/11/08 at 09:45 PM
if the bleed nipples are at the bottom on the rears you need to remove the calipers place the nipples at the top and re bleed then refit
austin man - 26/11/08 at 09:45 PM
sierra what disc or drum ?
if its disk I believe you have to lower the top of the calliper as air remains trapped within the calliper a part of the calliper (or was it raise the bottom?) we had this problem on an MK Indy.
omega0684 - 26/11/08 at 09:46 PM
might seem obvious but have you checked all the joins for leaks, get wifey involved to pump the brake! extra eyes etc
Howlor - 26/11/08 at 09:51 PM
Virtually guaranteed to be air in the system somewhere. An Eezi bleed system is really worth it.
I had the same problems but after a lot of bleedin bleeding I got them right!
A1 - 26/11/08 at 09:58 PM
cheers, its sierra discs at the rear, ill try removing the callipers and re bleeding tomorrow!
fingers crossed!!
Chippy - 26/11/08 at 11:15 PM
Just make sure that you put something in between the brake pads before you bleed them, (on mine I can just get them to sit on the disc's up the other way), otherwise the pistons will come out, destroying all your good work, :-( Cheers Ray
Paul (Notts) - 27/11/08 at 07:48 AM
as above!!!
speedyxjs - 27/11/08 at 08:04 AM
As said ezi bleed system is defo worth it and cheap. About £15 iirc
Antnicuk - 27/11/08 at 08:34 PM
i have the same set up to your, it took me ages to bleed the brakes fully. I did it 3 or 4 times iirc. Do you have seperate M/C's?
