Im having one of them moments!
Im trying to locate the clips that screw onto the master clutch cylinders for the pedals!
The master clutch cylinders are from a land rover.
Where can i get these from???
Think the part you want is a clevis, you'll probably need a clevis pin to suit as well. Try Car Builders Solutions , Europa Car Parts etc
