Remote bias bar adjuster?
tomgregory2000 - 9/8/09 at 08:34 PM
After a slight mashing of brake pedal bits im removing my lock nuts from my bias bar and want to fit a remote adjuster instead.
Couple of questions.
Are the cables flexible enough to run from the bias bar and then up the side of the car?or do i need a 90 deg adaptor?
Which adjuster should i go for?
Many thanks
Tommy
coozer - 9/8/09 at 08:43 PM
Get the flexi one and you'll be OK. Gives me the bums rush I need one too.
I still look at the bias bar and think its strange how one of the nuts has disappeared despite having a roll pin though it. Makes me wonder how safe the bias bar setups are....
britishtrident - 10/8/09 at 01:24 PM
Really best to avoid these things anything the tempts the driver to twiddle with the bias is a bad idea.
On a correctly set up racer the difference between wet aan dry bias settings can be as little as one turn and is seldom more than two --- for a road car this best left alone once set for the dry, for a club racer it is best done with care in in the paddock.
