Hi all, I need a new propshaft - any ideas? Cost is of course an issue!
Dan
What gearbox/diff? Do you have one that could be shortened or are you after a new/used one?
I have a Custom prop that fits a Sierra diff and T5 gearbox that is surplus to requirements. Let me know if it's what you're looking for and
I'll measure up and give you a price.
Cheers Alex
Very good questions! I am running a 1600 crossflow with standard(?) 4 spead box. The rear axle I am told is an escort axle - does that mean Escort
Diff or could it be a different diff as well?
The current prop is 1000mm from end to end but is a big diameter (looks like a sleeve has been welded on?).
I need a narrower one basically
