Some excessive toe-in on the rear lead to a brief investigation where it was discovered that the wishbone tube at the outer end of the rear lower
wishbone had broken off the end of the wishbone.
Broken wishbone toe-in
Broken wishbone
Broken wishbone
When installed, the crush tube was approx. 0.5mm longer than the polybushes. It appears that the mild steel crush tube has rusted and glued itself to
the polybush. The wishbone has then fatigued to failure. The seam in the tube is correctly aligned with the wishbone (although not all are). The
inboard end at the front, where it is less exposed to water, is in better condition but the inboard rear crush tube is also corroded.
Broken wishbone tube
Broken end of wishbone
Rusty crush tube
From the measurements I have taken, it appears that the MK Indy wishbones use identical polybushes and crush tubes to the Haynes Roadster. Can
anyone confirm this?
I will be replacing all of the polybushes and crush tubes with stainless tubing to prevent this happening again, and would strongly advise anyone with
mild steel crush tubes to do the same.
Being local, this looks like the best bet: Saturn
Sportscars
I also plan to use 0.5mm PTFE washers at each end of the bracket, the reduce friction between the steel bracket and the polybushes.
I'm no expert on welding but to me it looks like a bad weld i.e. not enough penetration. Even if your explanation of the tube/bush seizing is true I think the wishbone should bend before the weld would snap. The better makes of polybushes usually come with stainless crush tubes anyway.
Ah yes I completely failed to see that. Didn't have my 3D specs on. So actually the weld was pretty good. You should really take the bushes and tubes out once a year and lubricate it all. Don't use normal grease or it will damage the bushes.
IMHO
It looks to me that the whole assembly was put together with no lubrication whatsoever.
It was doomed to fail sooner or later.
Steel swells as it corrodes so joints only get tighter.
As this joint stiffened something had to give. In this case the weld.
If I remember DiySi had a similar problem. In his case the tube split.
Again IMHO, wishbones are not a "fit and forget item." Lube on assembly and check periodically.
Paul G
Again no expert.
But the crush tube has stopped rotating ( seized up ) so the up and down motion of the suspesion has been transfered into trying to break the weakest
point.
Regards
Agriv8
Not being critical but it does all look like it hasn't had any attention in quite some time - either that or a lot of water and salt over a
shorter period.
Stu
Originally posted by whitestu
Not being critical but it does all look like it hasn't had any attention in quite some time - either that or a lot of water and salt over a shorter period.
Stu
The car was correctly assembled 3 years ago and has been regreased once since. It is driven in all road conditions which will accelerate corrosion, but you do not expect this sort of problem after 11,000 miles. If this part is intended to be greased on a regular basis, then the joint should be fitted with a grease nipple. You should not be expected to completely rebuild your suspension every 6 months. If I wanted constant maintenance, then I would have fitted rose joints. Polybushes are sold as a "maintenance-free" option for road going cars, but clearly in this case the materials (i.e. mild steel crush tubes) are not suitable for the job.
Next time I remove my wishbones/trailing arms I'm planning on drilling a small (3mm ish) hole in the top centre of the polybush tubes, to gives
access to the void between the two bushes. The plan is that when the damn things start up with their perennial creaking and squeeking I can get the
extension tube of a tin of WD40 or similar in there and give them a good shot of lube.
Trouble is trying to seal these holes to prevent all the crap getting in there, especlally the rear trailing arms, where access to these points would
be rather limited. Maybe a small tapered rubber peg or similar could be pushed into the holes, I'm sure I'll think of something......
Originally posted by Agriv8
Again no expert.
But the crush tube has stopped rotating ( seized up ) so the up and down motion of the suspesion has been transfered into trying to break the weakest point.
Regards
Agriv8
Hi
These bushes where never designed to be used for this application. They are just cheap nasty general bushes.
I have said it before and ill say it again the UK kitcar market scene needs to have a kick up the arse and start producing and using parts that are
designed for an application rather than just using the cheap crap that they can make a BIG profit on.
If you take a look at just how many manufacturers are selling kits / cars with serious inbuilt designs and flaws that are going to result in cars
being in a dangerous unroadworthy condition at some point, the whole scene is really becoming just a joke and is now in a worse state than it was all
those years ago back in the late 70's 80's.
Cheers Matt
Originally posted by GeoffT
Next time I remove my wishbones/trailing arms I'm planning on drilling a small (3mm ish) hole in the top centre of the polybush tubes, to gives access to the void between the two bushes. The plan is that when the damn things start up with their perennial creaking and squeeking I can get the extension tube of a tin of WD40 or similar in there and give them a good shot of lube.
Trouble is trying to seal these holes to prevent all the crap getting in there, especlally the rear trailing arms, where access to these points would be rather limited. Maybe a small tapered rubber peg or similar could be pushed into the holes, I'm sure I'll think of something......![]()
Look through the archives; this exact same problem has cropped up numerous times. I would not recommend mild steel crush tubes be used with these "poly" bushes.
Hi
That's correct WD40 dries out and then act as more of a glue than a lubrication in this situation.
And yes again mild steel is not correct for use in this application either. Proper bushes designed for this sort of application always come with
stainless pivots.
Cheers Matt
I have said it before and ill say it again the UK kitcar market scene needs to have a kick up the arse and start producing and using parts that are designed for an application rather than just using the cheap crap that they can make a BIG profit on.
The cars may have been tested by VOSA against specific requirements but this does not assure conformance to any warranted design techniques. It would
be a fair bet that no kits have a detailed design process, DFMEA's, NPI project management or detailed test analysis carried out during
development. If they did then few of us could afford them. Until production volumes allow such luxuries then unfortunately you have to treat the cars
as amateur built and accept the maintenance and on-road prototype developing that it gives.
It is a hinderance that the suspension will need to be stripped down periodically but if that maintains the high level of enjoyment that these cars
give then i guess its a small price to pay. Think of these cars more like vintage and classic cars rather than compare to the reliability of todays
road cars. the bottom line is that kit cars arent suited to those without a fair degree of spannering ability.
Im not saying i disagree with what you are saying by the way, over time and with continuous improvement yours may not need such a high level of
maintenance. Sounds like you have some good ideas.
Its probs worth saying that the reason others may say there cars dont need to be rebuilt so often is that they are not aware of the potential problems
and havent checked. you are aware and will have a better car as a result.
There is no reason that a kit car can't be used everyday and there is no reason not to expect equal reliability to a regular car. After all, these cars have been tested by VOSA to state they are fit for purpose.
Originally posted by DarrenW
The cars may have been tested by VOSA against specific requirements but this does not assure conformance to any warranted design techniques. It would be a fair bet that no kits have a detailed design process, DFMEA's, NPI project management or detailed test analysis carried out during development. If they did then few of us could afford them. Until production volumes allow such luxuries then unfortunately you have to treat the cars as amateur built and accept the maintenance and on-road prototype developing that it gives.
I was led to believe WD40 contains kerosene or something similar and therefore isnt a good long term option for lubricating such a joint.
Anybody know what Caterham use for bushes / sleeves?
Hi
And yes again mild steel is not correct for use in this application either. Proper bushes designed for this sort of application always come with stainless pivots.
Cheers Matt
Originally posted by MK9R
BUt top be fair lubricant isn't what you need here, these bushes aren't designed to rotate, the rubber is supposed to flex during rotation
[Edited on 14/12/10 by MK9R]
Except the subject of this thread is not rubber bushes - it's poly bushes which are intended to rotate relative to the crush tube.
Stainless crush tubes and grease nipples for belt and braces gets my vote.
[Edited on 14/12/10 by Liam]
Hi
Cheers Matt
WD40 isn't a lubricant, you need something like Q20 (shameless plug) that is a proper lubricant and water dispersant
Another way of putting that is 'Let's close down the UK kit car industry'. By definition the manufacturers do not have the budget to make cars to the same standards as big manufacturers.
I'm not saying that your bushes weren't a bit crap [mine are the the same and are fine after 4 years], just that if we apply main manufacturers standards to kit cars they will disappear, and personally I don't want that to happen.
Stu
Can i ask did you build the car and if so what type of grease did you use when putting the wishbones together
I think i will have to strip and check mine over winter
Do you think this would have happened if you had used copper slip
Jacko
[Edited on 14/12/10 by jacko]
I removed my front upper bushes when I swapped over to rose joints and after 3 years they were pretty much the same as when I installed them [using
sicilcone grease], but my car has had done nearly all dry miles which probably makes a huge difference.
Stu
I built the car in 2005, on the road in 2007. I can't remember which grease I used. I believe it was either silicon grease or molybdenum grease. The car has been regreased once around 2008. In 2009 the front end was disassembled to correct the castor. Seeing no issues at the front it was assumed the back was in similar condition. I have been looking into synthetic grease with either a PTFE or molybdenum additive for reassembly. It would be interesting to see photos of what other peoples crush tubes look like after. Bear in mind that I drive in all road conditions, not just dry roads. It is thoroughly washed off after winter gritting, but it does greatly accelerate corrosion.
