gaz dampers
Lars - 1/7/04 at 01:17 PM
was just trying to roughly set ride height and noticed that one of the dampers was quite greasy, so took it off and found it to move with less resistance than the others.
Is the damper leaking or is it normal?
cheers
Lars
alfasudsprint - 2/7/04 at 10:17 AM
mine are not at all greasy, possiblke leak of course, did something get spilt on them though, either by you or before you got them...only way is to clean them up any observe for future leaks, no?
Tim
Lars - 3/7/04 at 07:08 AM
had another look at it moves much easier than the others.
Didn't spill anything on it.
It's on its way back to be repaired, still under its 3 year warranty
