Hi
Has any one got a correct Drawing for a Ron Chapmans Locost Front Top WishBone
I under stand that the Drawing in the book is wrong
thanks
Champion, not Chapman. Who is that Chapman guy anyway?
Search function is your friend:
Some info here:
http://www.locostbuilders.co.uk/viewthread.php?tid=146104
http://www.locostbuilders.co.uk/viewthread.php?tid=128655
It's pretty simple thank goodness.
The castor is stated in The Book as being 11mm. But to make the specified 5.5 degrees that you need it should be 22mm.
Still worth building some adjustabilty into the suspension though as even 22mm may not be enough to self centre and get you through the IVA.
James
Thanks guys
