right my mk blade has 250lb 9inch on the front and i can not get the correct rake on my car so looking to change them but what springs do i change them for, and the shoks are protech any help would be good
250 is not far off.
200-225 are oftem used for becs
explain more about the correct rake that you cant get?
it mab be the length that is the problem rather than the poundage I would suggest shorter springs
9" does sound very long to me. Dropping to 8 should do the trick.
so 8 would sort it then
Well that would depend on what the issue is in the first place!? What do you mean by 'correct rake'? Correct front ride height? Is that because the spring pan has reached the bottom of the thread? If so then yes it will help.
