Been playing with my brakes today and not sure if my master cylinder is working correctly, When I pump the cylinder and put my fingers over the front
two outlet and pump the cylinder I can feel the pressure building up.However when i do this for the rear outlet I can barely feel anything.
Also If I fill the reservoir with fluid, the rear outlet start to drip fluid without depressing the piston. Is this normal ?
Dave
sounds like the plunger may be set up incorrectly there should be a little free play between the plunger / rod and the piston, have you checked this?
Hi austin
Yes there is free play between the push rod and plunger (with the stop fully wound in I have about 10mm free. You can also see that the washer on the
plunger is fully back against the circlip.
Bump
Anyone able to offer any advice?
Dave
