rose jointed track rod ends
pre lit - 12/6/11 at 04:57 PM
i want to convert my escort rack to rose joints does any body know who does a kit.
i dont want to use the ones like the extenders you fit when fitting widetrack. i just want to use a female rose joint on to the rack arm so prob need the complete arms converted to take a joint and then an adapter to fit in the taper part of the hub(cortina uprights)
any help appreciated
TimC - 12/6/11 at 05:54 PM
Douglas @ Westgarage or Matt @ Procomp or Dave @ Track Developments should be able to sort out the taper and associated parts.
I'm less certain about your female rose joint; what thread is the Escort rack (I've not got there yet)? One observation would be that the female RJ might be shorter than the TRE.
