Hi All, got to change the diff oil any ideas on the best grade to use. also where is the fill hole on a escort mk 2
EP90 Hypoid Gear Oil was the original grade a multigrade is a more modern choice but it must be an GL5 EP oil suitable for Hypoid gears. for
example CASTROL AXLE EPX 80W-90 or CASTROL AXLE EPX 85W-140
Level plug is on the rear of the diff -- car must be sitting level when filling.
