Just a thought, but
If i was to fit bigger 10 mm diameter disks, but retain the same calipers and pads,
and space the calipers out by 5mm
so that the pads were to sit 5mm further away from the hub,than they currently do
Would this affect the brakes, if so, better or worse,
or in real terms, would not make a jot of difference
Regards
imho
In real terms not a jot of difference
In theory improved braking force for the same pedal pressure
I would expect the braking to be better, because you would be getting more rechanical advantage by having the pads further out from the centre of the
hub.
They would be no better at dispersing the heat though, because the pad area would nt be an bigger.
There would be an improvement, but whether its detectable is another matter.
The increase leverage 5mm would give is probably not worth all the effort, think of a stiff bolt, would 5 or 10mm extra leverage make that much
difference?
Thanks guys,
I was under the same impression, so will probably leave as is
regards
The increase leverage 5mm would give is probably not worth all the effort, think of a stiff bolt, would 5 or 10mm extra leverage make that much difference?
Or you could get much the same effect by machining 10mm off the inside radius of the pads. That would give pretty well the same mean braking
radius.
Of course the pads would heat up quicker but that might be a "good thing" if a braking system designed for a heavy car is used on a light
car.
Other benefits are a reduction (marginal) in unsprung weight rather than the increase in unsprung weight a larger disc would have.
In addition if there is room to fit a bigger disc I presume you have room to move the callipers outwards? So do it anyhow. Usually there is a 5mm wide
unused band at the edge of the disc which should be utilised.
So in true locost fashion you can get twice the effect of a larger disc for bu66er all just a bit of fiddling about here and there
Only disadvantage is the pads would wear out quicker and unevenly but how many locost cars wear out the pads anyhow?
Cheers!
Having read SCARS post thats about 10% for nothing
[Edited on 8-1-12 by v8kid]
Originally posted by Xtreme Kermit
I would expect the braking to be better, because you would be getting more rechanical advantage by having the pads further out from the centre of the hub.
