As a complete newbie, wot does a LSD look like and how can I tell if it is working or not. Also wot is the best ratio to use with a 2.0l pinto ???
The simplest way to determine if a vehicles fitted with an LSD is to raise the driven axle off the ground and turn one of the wheels. If the opposite
wheel turns in the same direction, it's an LSD. A counter-rotating wheel proves otherwise.
Neil.
Hey u r right !!
Thanks for that.
Graham
I'm aiming for acceleration. I can't see the point in having cars capable of 150mph! I've checked the diff. and the tag has rusted away but by turning and counting I reckon its 3.62 (ish !!!).
What are you planning to do about the speedo? Bear in mind the difference between 3.9 and 3.62 is about 8%.
It's only an issue if you're planning to re-use the donor's speedo I guess.
James
James
I don't have a donor yet. A pinto came up for sale and when I got there he also had a diff. The guy said it was LSD so I had it away, willing to take
the risk that it was an ordinary unit. Hence my first post. It is a LSD so like u say I have the added problem of matching a speedo to it.
I'm really only planning my build yet and getting a few bits together. I've left it a bit late throu - my new MK chassis came today !!!!!!!
Or reduce(?) your tyre diameter by 8% to compensate.
Presumably speedos that are sold (by the likes of Raldes etc. etc.) are calibratable otherwise life's gonna be very hard!
I was thinking of using the donor speedo (to get me through SVA) and the tyre trick will do until I get some nice clocks!
James
Try this link
http://www.fernblatt.com/longhurst/tyre_bible.html
Tells you how to select a tyre profile to match your new bigger wheels (plus lots of good stuff as well.)
