As seen at Stoneleigh
Half the weight of standard Sierra
[img][/img]
[img][/img]
Direct swop apparently
£225+vat each
Wow they are expensive! You can get a pair of alloy Cortina uprights for £195 + VAT, you then just need a new set of top wishbones (extended by 19mm I believe) and a new pair of steering rack extensions. Granted you may need to source a pair of Cortina hubs but I can't image they will be too expensive.
I had the first pair they sold , I am building a mk indy rr for the road and aiming for under 500kg , slight problem with the outside diameter of the
hub meaning they had to scrap existing hubs and remake a new batch, got them fitted and look great , the weight difference is crazy. A good saving
in unsprung weight.
[Edited on 5/5/15 by raptor700]
Originally posted by raptor700
I had the first pair they sold , I am building a mk indy rr for the road and aiming for under 500kg , slight problem with the outside diameter of the hub meaning they had to scrap existing hubs and remake a new batch, got them fitted and look great , the weight difference is crazy. A good saving in unsprung weight.
Yeah defo will get some up for you
