Hello,
I'm in the process of changing the master cylinder to a fiat one. I bought a draper flare kit, which iv'e got reasonable results with. The
question is.... is the single flare in the image ok for male unions or do I need a double/bubble/other flare?
The picture appears to be a double (concave) flare. Probably not right but would need to seen the hole in the master.
Ok, I just put the pipe into the clamp bar, then just used the v shape flare tool to flare. The instructions refer to it as a single flare, though when looking online I cannot see many references to this type.
looks wrong way round to me
[Edited on 14/8/15 by rash12]
what rash said ^^^...have a look down the port in the master,it will be the oposite of what you put on the pipe
Yeah, its definitely not that type, its essentially just a tapered v, looks like I'll need to change.
Note that a double flare is not formed purely using the V shaped tool, you need to form a convex single flare using the former first then use the V
shaped tool to fold it in on itself. Video here: https://www.youtube.com/watch?v=4fmF9mm3hsM
I realise this may not be what you need for your master cylinder but a lot of DIY'ers are not aware how the double flare is formed.
What has thrown me (apart from a lack of experience!) is the draper manual referred to it as a single. I can find another link to that type (image 4),
though as highlighted this isn't the correct type for the master cylinder.
[Edited on 14/8/15 by adamswifty]
Hi
A male is shaped like a knob end when you make a female you should always make a male knob end first and then convert the knob end to female.
If you get a few inches of copper pipe and join them with connectors you will end up doing one male knob end with one half and with the other a male
knob end which is then flared again with the female attachment.
You should never just do a single female flare as you will end up with very thin "lips" which when you tighten the joint they can break off
and leak.
I always wrap the joints when first done with a scrap of material and check later that they are dry to prove the joint.
With the connectors the male goes into the female and the male has a male end and the female a female.
Hope this helps
Nick M
Thanks Nick, will re-flare
Originally posted by nickm
Hi
If you get a few inches of copper pipe and join them with connectors you will end up doing one male knob end with one half and with the other a male knob end which is then flared again with the female attachment.
You should never just do a single female flare as you will end up with very thin "lips" which when you tighten the joint they can break off and leak.
Hope this helps
Nick M
You should never use the "V" shaped tool to make a flare without first putting a single flare on the pipe, I'm surprised it hasn't
split around the edge!
